OZVMX.COM
May 22, 2013, 08:08:03 AM *
News:
Pages: 1 [2] 3  All   Go Down
Author Topic: YZ125A Tank question.  (Read 3190 times)
frostype400
View Profile
« Reply #15 on: December 30, 2011, 06:55:38 PM »
I can measure the rm250a tank this weekend.
1971 tm400 and PE's
Slakewell
Slakewell Motordrome
View Profile
« Reply #16 on: December 30, 2011, 07:04:51 PM »
Firko
The YZ 80 A tank are held by 2 rubber inserts that hold it to the frame at the front that fit too spigots under the tank near the front and a normal 6mm bolt at the rear. I'm sure you could retro fit the works strap from the bigger bikes and yes they can be purchased new on the interweb. Knock up some brackets that fit onto the spigots that the straps clip into
Many people speak of my drinking but no one speaks of my thirst
Davey Crocket
View Profile
« Reply #17 on: December 30, 2011, 07:27:51 PM »
I may have some tank straps left from the ones I had made up Mark, the 125 straps are smaller than what the parts book lists(125/250/360 the same)....there is a set of 453 staps on US ebay at the moment (Scooterboy), but he wants drug money......do the Torsten Hallen prototype YZ tank paint scheme....looks good....red/white combo. 125 tanks do come up for sale and if you get one with no threads left on the feul tap spigot, I have new ones ready to weld in. Cheers....hows your mum?
Rossvickicampbell
View Profile
« Reply #18 on: December 30, 2011, 10:17:56 PM »
did the bigger As come with straps - or just the Bs?
Changed my mind again - now I want a 1977 RM370B?
Davey Crocket
View Profile
« Reply #19 on: December 30, 2011, 11:31:13 PM »
The 3 big A's and B's all had straps.....just like the works ones.
frostype400
View Profile
« Reply #20 on: January 01, 2012, 11:32:23 AM »
The rm250a tank is roughly,
450mm at it's longest.
About 200mm at widest.
Down to about 110mm wide before it drops off.
390mm long from the neck to then end of the tank.
Only rough measurements I can send it to you whenever you like, thanks Michael.
1971 tm400 and PE's
iainyz
View Profile
« Reply #21 on: January 13, 2012, 07:03:27 PM »
Mark try Dan at motographic in Silverwater Syd ,He makes nice stickers . By the way the RT1 nifty built has a YZ80 B alloy tank and home made straps .
Yamaha tragic ;at1, dt1, rt1, dt2, rt2, mx250, mx360,sc500,dt125, dt360, tya 250, 74dt125, yzx125, yzc250, yzc400, yzd250, yzd400, yzh250, yzh80 still to finish dt250 75, rt2mx, dt2mx, 3x dt1s; looking for 75 mx 250,400. rides with Tas scramble club
View Profile
« Reply #22 on: January 14, 2012, 01:17:19 PM »
It's surprising how well the YZ80 tank fits. If someone would have told me to try one a week ago I'd have told them they were being silly. I''ve made the decision now and will soon be sending it off to the painters for its cool retro OW paint scheme.
In a gadda da vida .
'68 Yamaha DT1 enduro, '69 Yamaha 'DT1 from Hell'
'69 Cheney Yamaha 360, 70 Maico 350 (2 off), '68 Hindall Ducati 250, '72 Hindall RT2MX, 70 Hindall RT1 flat tracker, Champion DT1 flat tracker, Yamaha 1T250J, Maico 250 trials, '71 Moto Islo Metisse, Boyd and Stellings TM400.
Taka 100
« Reply #23 on: January 14, 2012, 02:24:11 PM »
re the molasass , i have recent done a 125S and a CZ tank moderatley rusted and found that it works the best after you wash out the tank with fresh fuel and then thinners etc then throw in a handful of crushed blue metal gravel and shakeit all about to loosen some of the rust then topup with molasses and water mix to the rim after you tape up the outlet hole let it sit for 2days empty it out leave the handfuls of crushed gravel (it has some nice little edges on it ) in and shake all about flush with clean water then do the process again after straining all the crap outa the mixture , another 2 day some more shakin and flushing and its sweet as , leave super rich fuel / oil mix in for a while then empty new filters and it ready to go baby!!!
View Profile
« Reply #24 on: January 14, 2012, 02:30:42 PM »
Thanks Taka........I'll get into it during the week. I've got some welding to do to the rear mount and one little  rust pinhole. Even though it's fixable it's not the greatest tank so if anyone's got another I'd be happy to take it off your hands.
Slakewell
View Profile
« Reply #25 on: January 14, 2012, 04:04:40 PM »
Bejebus Firko that looks more rusted than when I gave it to you 20 years ago.
View Profile
« Reply #26 on: January 14, 2012, 04:17:14 PM »
So that's where it came from Grin. It had me buggered how I ended up with it. I had it stored in a metal locker in my garden shed that unfortunately got a bit of water into it. The tank sat upside down in about a quarter of an inch of water, luckily all the rust damage is outside, inside's pretty good considering. There was a nice Cole brothers Maico pipe whose header pipe didn't fare so well, it's rusted tight through..but everything's fixable!
Slakewell
View Profile
« Reply #27 on: January 14, 2012, 04:30:49 PM »
Firko I think if you look closely it even has a bit CMB engineering orange paint split on it.
View Profile
« Reply #28 on: January 15, 2012, 08:27:23 AM »
that fits great, should be good for getting forward in the turns too
View Profile
« Reply #29 on: January 15, 2012, 10:48:43 AM »
I think you're right Paul, the plan is to get the ergo's as comfy as possible, I want the seat and tank to be the same width with as seamless a join as possible without opting for a non era 'safety seat'. The seat shown on the bike is off my Cheney but the new one will be very similar in width but  slightly longer. I can't build it until the mudguards are fitted so I'll know exactly how long to make it. Here's another view............
Pages: 1 [2] 3  All   Go Up
Jump to:
